miogpsrocks
Feb 03, 2018Tutor
"ERR NO DISK DETECTED" What is going on?
Readynas has 6 drives installed, formatted from a factory default clean install. Its a legacy running OS6. Each drive is 4TB X 6 drives with XRAID I moved about 1TB of data over from my ol...
miogpsrocks
Feb 03, 2018Tutor
*** UPDATE. I unplugged it from the UPS and plugged it directly into the wall and now it seems to be working.
Maybe I need some device produce a cleaner power signal from a UPS than the standard UPS, I'm not sure.
I searched on google and other people with this issue have mentioned it might be related to a power supply?
What do you think?
Thanks.
- mdgm-ntgrFeb 04, 2018NETGEAR Employee Retired
It’s also possible that your UPS could be faulty or too low aspec to be able to output enough power for what the NAS needs.
Which UPS do you have?
- miogpsrocksFeb 04, 2018Tutor
Its an APC Backup 550.
However we did have a hurricane here in Florida not too long ago in 2017 and I was without power for like 12 days and I was using the UPS and small backup generator to keep my fish tank alive. So maybe the UPS is overly stressed and not in perfect condition however I do use it for a smaller Readynas NV+(4-drive) and it has always seems to have worked just fine.
Anyway, it appears there was not enough power to turn on the hard drives. Perhaps I should get a better UPS and try that?
Right now its seem to be working fine while plugged directly into a wall but that is not a good long term solution.
Thanks.
