ismaeljk
Dec 17, 2015Tutor
Erratic Access to Folders
I have just updated to firmware 6.4.1 from 6.4.0. I had been having access problems, where connection to the server seemed to last a set amount of time and then we were kicked out. With the upgrade...
- Dec 20, 2015
Hi ismaeljk,
Does this also happen using AFP? If you will turn off AV, will it make a difference?
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
ismaeljk
Dec 17, 2015Tutor
The first image below shows the files when browsing via the Netgear Admin page. The following image shows what can be seen in Finder ... After a long wait one of three options is possible - no files show in Finder, all files show in Finder, or you get kicked out of the shared folder and cannot acces it until you disconnect from the Shared Folder and connect again.
- ismaeljkDec 17, 2015Tutor
- BrianL2Dec 20, 2015NETGEAR Employee Retired
Hi ismaeljk,
Kind regards,
BrianL
NETGEAR Community Team- ismaeljkMar 30, 2016Tutor
Hi Brian,
Thank you for your response. Using AFP did not work, but turning off AntiVirus I think has worked wonders. I will confirm in a few days when we have had a chance to test it a bit more...
What are the consequences of this?
