ismaeljk
Dec 17, 2015Tutor
Erratic Access to Folders
I have just updated to firmware 6.4.1 from 6.4.0. I had been having access problems, where connection to the server seemed to last a set amount of time and then we were kicked out. With the upgrade...
- Dec 20, 2015
Hi ismaeljk,
Does this also happen using AFP? If you will turn off AV, will it make a difference?
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
