ismaeljk
Dec 17, 2015Tutor
Erratic Access to Folders
I have just updated to firmware 6.4.1 from 6.4.0. I had been having access problems, where connection to the server seemed to last a set amount of time and then we were kicked out. With the upgrade...
- Dec 20, 2015
Hi ismaeljk,
Does this also happen using AFP? If you will turn off AV, will it make a difference?
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
ismaeljk
Dec 17, 2015Tutor
BrianL2
Dec 20, 2015NETGEAR Employee Retired
Hi ismaeljk,
Kind regards,
BrianL
- ismaeljkMar 30, 2016Tutor
Hi Brian,
Thank you for your response. Using AFP did not work, but turning off AntiVirus I think has worked wonders. I will confirm in a few days when we have had a chance to test it a bit more...
What are the consequences of this?
- JennCMar 30, 2016NETGEAR Employee Retired
Hello ismaeljk,
If disabling AV fixed it then your NAS is affected by the performance issue which was discovered few months ago that started at 6.4.0, I think. BETA FW has been already release to address this, that's 6.5.0-T338 (Beta 2) in case you want to try.
Official one will be released soon.
- ismaeljkApr 08, 2016Tutor
Thank you - will wait for 6.5 to be tried before installing.
