f2f
Oct 04, 2026Aspirant
Erro connecting to folder
I am using connected my remote office with site to site vpn and truing to add folder in NAs but getting error. in my local PC i am able to open this salred ip folder but in nas getting error
f2f
Oct 08, 2026Aspirant
Site to site VPn with remote location ,Admin credintial i am using .i am able to access remote ip locally in my PC but in NAs not able to connect this folder
Oct 08, 2026Guru - Experienced User
f2f wrote:Site to site VPn with remote location ,Admin credintial i am using .i am able to access remote ip locally in my PC but in NAs not able to connect this folder
So this is an existing folder? (you said "add folder" in the first post).
And you cannot access it either with SMB or with the NAS web ui?
When you use your browser, are you logging into the NAS web ui (https://nas-ip-address/admin) or are you going directly to the share (https://nas-ip-address/sharename).
- f2fOct 09, 2026Aspirant
i am able to open NAS in web browser but while adding user floder its getting error
- StephenBOct 09, 2026Guru - Experienced User
I'm still not fully understanding, and the details here matter. I don't know if you are talking about a public share, a user's "private" share or subfolder within an existing share.
When you say "user folder", do you mean you are trying to manually create the private "home" share for that user? That cannot be done (instead you would need to create a user account, and the system would create the private share ).
Are you are trying to add a folder to a user's private "home" share? That can only be done if you are using that user's credentials.
Are you trying to add a public share?
Or are you trying to add a folder to a specific public share? If so, have you checked both the file and network permissions in the shrae settings?
