Lonestar44
Jan 01, 2019Tutor
Error 0x80004002 No such interface supported
Never had any propbles until undating Win 10 to build 1809. I can access the NAS with RAIDar. I can access it by serching in file explorer for the ip address, I can see it listed under storage dev...
- Jan 15, 2019
I was fortunate to find a solution for the issue that I posted for. What was causing the problem with my system is that NetBios over Tcpip was not enabled, even thou it was shown to be set in the network adapter advanced TCP/IP settings dialog.
I was able to determine that by checking its status from a command prompt with ipconfig /all.
I downloaded the current driver for my network card, in my case it was a Realtek PCIe GbE Family Controller and made sure it was updated to the current version.
Went to the Ethernet properties dialog menu for the Realtek and unchecked everything that was selected, clicked ok and closed.
Opened device manage and uninstalled the network card and rebooted. Windows reinstalled the card on reboot with the drivers previously updated.
All of the previous settings were confirmed to be reselected in Ethernet properties.
NAS now shows up as it should under the Network tab in file explorer and functions as it should.
Interesting thing is I still get the same error when I click on the NAS on the right side of file explorer under the storage dialog.
Hope this is of some help.
Lonestar44
Jan 02, 2019Tutor
Thanks! That successfully mounted the NAS as a network drive. There were none mounted. Which is fine. Any idea why this does not work like it did, showing it under the Network? I still get the same error if I click on the NAS under the storage tab. It seems as though it is trying to download a file. The whole thing is weird. I hate Win 10, everything works one day and the next it goes to #@$. I have used computers since DOS and this reminds me of Win 95.
Thanks again for the help.
Jan 02, 2019Guru - Experienced User
The NAS should show up as a storage device under network, though sometimes that fails. That was also the case with older versions of Windows also, and I don't know of any surefire way to fix it.
Personally I just enter \\nas-ip-address in the file explorer address bar to access the NAS. You can also add NAS shares as network locations from "This PC", or create desktop shortcuts that access the NAS when you click on them.
Overall, Microsoft is tightening up on anonymous access. So I also recommend entering a NAS credential into the Windows Credential Manager, using NAS account credentials. You can use "admin" for this, or create a user account on the NAS. If you access the NAS by both hostname and IP address, then enter two credentials (one for the hostname, and one for the IP address).
- SandsharkJan 03, 2019Sensei
I have the same problem since one of the Windows updates. Work-arounds are stick with using the IP address or add the name to the HOSTS file. I know of no true solution.
- Lonestar44Jan 15, 2019Tutor
- Retired_MemberJan 15, 2019
Lonestar44 wrote "NAS now shows up as it should under the Network tab in file explorer and functions as it should. "
Great, thanks for sharing this. You might want to accept your reply as the solution to this issue, though.
