mrvincent
Sep 15, 2017Aspirant
Error: DO_RAW_SPIN_LOCK+C, need to resync...
Hi, I think it's after a reboot... I rebooted my ReadyNAS 104 then went to job, then realised I wasn't able to access it... Came back to home and it's displaying: DO_RAW_SPIN_LOCK+C.... I went so...
mrvincent
Sep 18, 2017Aspirant
Ok, after 2 days "re-syncing", it went back this morning froozen with DO_RAW_SPIN_LOCK+C and started back re-sync from scratch...
I'll factory reset it, hope I can get back all the data back from it...
It could be VERY NICE if somebody find what causes that, so community don't get this problem again...
Sep 18, 2017Guru - Experienced User
Unfortunately, a factory reset does destroy all the data.
- mrvincentSep 19, 2017Aspirant
Yeah I know, did my 4TB backup, took a while, did factory reset, put back the settings... Then I'm transfering back my data..... This is ridiculously long... And this is about the third time I get strange errors like this with this netgear product....
I just wanna understand what's is going wrong... So it won't happens again...
- Marty_MSep 25, 2017NETGEAR Employee Retired
Hello mrvincent,
The error may occur due to a lot of possible reason. I believe in your case it can possibly determined if our engineers can have remote/console access to the NAS to debug it.
Marty_M
NETGEAR Community Team- mrvincentSep 25, 2017Aspirant
I already did a factory reset...
