mrvincent
Sep 15, 2017Aspirant
Error: DO_RAW_SPIN_LOCK+C, need to resync...
Hi, I think it's after a reboot... I rebooted my ReadyNAS 104 then went to job, then realised I wasn't able to access it... Came back to home and it's displaying: DO_RAW_SPIN_LOCK+C.... I went so...
Sep 18, 2017Guru - Experienced User
mrvincent wrote:
I'll factory reset it, hope I can get back all the data back from it...
Unfortunately, a factory reset does destroy all the data.
mrvincent
Sep 19, 2017Aspirant
Yeah I know, did my 4TB backup, took a while, did factory reset, put back the settings... Then I'm transfering back my data..... This is ridiculously long... And this is about the third time I get strange errors like this with this netgear product....
I just wanna understand what's is going wrong... So it won't happens again...
