pdelges
Aug 22, 2013Guide
Error making EXT3 filesystem on the USB device
Like every 6 monthes, I wanted to back up a share on an external drive and followed my usual procedure: plug a USB drive on my NVX, format the drive (EXT3) and launch the job. Surprisingly, the NVX...
chipmunk1
Nov 16, 2013Aspirant
OK - I can confirm that when you type the password that the cursor does NOT move. This is correct. Also, while I have managed to log in fine, I had to use my previous password, not my latest admin password. Maybe mdgm can advise what password should be used? Possibly the first password you used when you setup the NVX?
