pdelges
Aug 22, 2013Guide
Error making EXT3 filesystem on the USB device
Like every 6 monthes, I wanted to back up a share on an external drive and followed my usual procedure: plug a USB drive on my NVX, format the drive (EXT3) and launch the job. Surprisingly, the NVX...
mdgm-ntgr
Jan 26, 2015NETGEAR Employee Retired
This has been fixed internally so the fix will be in 4.2.28.
If you are comfortable with SSH you can install the fix from our 4.2.28 repository.
First edit /etc/apt/sources.list to use the 4.2.28 repository using vi
Then do
Then edit /etc/apt/sources.list to use the 4.2.27 repository again
# vi /etc/apt/sources.list
Then do
# apt-get update
# apt-get install e2fslibs
# apt-get update
cenjui
Sep 19, 2015Aspirant
I had the same fault adding a new internal volume on my NAS.
While the fix from mdgm worked, and thankyou for that, its really fustrating that it took a good bit of googling to find the answer and I've disposed of a disk that I suspect was perfectly fine as I couldn't get it to create a file system... Perhaps serious faults such as not being able to create new volumes should have a bot more publicity about them...
David.
