pdelges's avatar
pdelges
Guide
Aug 22, 2013
Error making EXT3 filesystem on the USB device
Like every 6 monthes, I wanted to back up a share on an external drive and followed my usual procedure: plug a USB drive on my NVX, format the drive (EXT3) and launch the job.
Surprisingly, the NVX refused to format the drive, here is what I got in the system.log:
Jul 26 12:10:25 BU-2TbRaid exportfs[15263]: /etc/exports [2]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/USB_HDD_2".   Assuming default behaviour ('no_subtree_check').   NOTE: this default has changed since nfs-utils version 1.0.x
Jul 26 12:10:25 BU-2TbRaid exportfs[15263]: /proc/fs/nfs/exports:1: unknown keyword "test-client-(rw"
Jul 26 12:11:53 BU-2TbRaid RAIDiator: Error making EXT3 filesystem on the USB device. [USB_HDD_2]
Jul 26 12:12:58 BU-2TbRaid RAIDiator: Successfully created FAT32 file system on the USB device. [USB_HDD_2]
As you can see, it was possible to format the drive with FAT32, but not with EXT3. The NVX runs latest radiator: 4.2.24
I tried at home with my Ultra2+ (raidator 4.2.23), and I could format the drive in EXT3 (and the NVX is now doing the backup job).
Last time I tried, and succeded, to format the USB drive on the NVX, it was still running raidator 4.2.22
Is it a known issue (I couldn't find anything on the forum!)?
p
ProSupport for Business
