lndshrk
Jul 10, 2010Aspirant
Error while backing up w/ RSync on 4.2.12
Backing up from one NAS to another via RSync. Both brand new RN Pro BE's on 4.2.12 - oriignally Factory-defaulted on 4.2.11 w/ ext4 filesystems and dual redundancy. Getting a similar failure as ...
mdgm-ntgr
Jul 12, 2010NETGEAR Employee Retired
lndshrk wrote:
(There are whispers of a kernel issue - other whispers of an out-of-memory
condition - and yet others of an interaction between certain NIC hardware
and rsync - but nothing proven - and nothing "fixed")
Memory should not be an issue with the Pro. The stock 1GB should be fine.
Hopefully NetGear can help with your issue.
lndshrk wrote:
Trust me, I wish rsync "just worked". It doesn't.
Well I guess our experiences differ.
I hope NetGear can help you with your issue.
Btw have you tried creating a snapshot and backing up a snapshot of your data. Do you still get the issue then?
