lndshrk
Jul 10, 2010Aspirant
Error while backing up w/ RSync on 4.2.12
Backing up from one NAS to another via RSync. Both brand new RN Pro BE's on 4.2.12 - oriignally Factory-defaulted on 4.2.11 w/ ext4 filesystems and dual redundancy. Getting a similar failure as ...
mdgm-ntgr
Jul 12, 2010NETGEAR Employee Retired
If you take a snapshot under Volumes > Snapshot and then backup sharename-snap you can use this to rule out files changing on the source ReadyNAS during the backup job as the issue. You still use Rsync to backup the share, you just backup sharename-snap instead of sharename.
