lndshrk
Jul 10, 2010Aspirant
Error while backing up w/ RSync on 4.2.12
Backing up from one NAS to another via RSync. Both brand new RN Pro BE's on 4.2.12 - oriignally Factory-defaulted on 4.2.11 w/ ext4 filesystems and dual redundancy. Getting a similar failure as ...
mdgm-ntgr
Aug 10, 2010NETGEAR Employee Retired
I would consider updating your production box to 4.2.13 as this may solve the problem.
However if you like, you should try to troubleshoot the problem with the backup box first to determine the cause. There could e.g. be a faulty ethernet cable, faulty port on the router/switch or some other issue.
