hussVLC
Aug 21, 2026Aspirant
error with rsyn 7077010012
Dear community, I am reaying to setup with my readnas102 a remote connection to server to backup, using the remote rsync but I get teh error above, and as I run a test with putty to connect to se...
hussVLC
Aug 22, 2026Aspirant
well the idea was with SSH but we started with simple RSYNG, on the remote server it is active as the support from the hosting company confirms. And for theh SSH they imported the SSH Key but even with that done we get the error to connect, what are we missing?
- StephenBAug 22, 2026Guru - Experienced User
It might be easier to troubleshoot this if you use the linux command line instead of the NAS backup job. Once you get the basic folder copying working, it should be pretty easy to get the NAS backup job to work.
There a lot of things that could be wrong.
- hussVLCAug 23, 2026Aspirant
i did test using putty, but I dont have the knowledge how to use linuex from windows oto program the tasks
- SandsharkAug 22, 2026Sensei
That's a permissions error. This may help: Duo v2 NAS-NAS RSync frustration | NETGEAR Communities
Thank you, I made sure there is a trailing slash and no initial one, but no change, still error in connection
- StephenBAug 23, 2026Guru - Experienced User
You also need permissions to write to the cloud server folder. Since you are just using rsync, then you might need to put in the cloud server credentials in the NAS backup job. The cloud server shouldn't allow any random rsync to write to your folder.
Note these credentials are sent in clear-text unless you use rsync over ssh, so you really ought to be using that.
