hussVLC
Aug 21, 2026Aspirant
error with rsyn 7077010012
Dear community, I am reaying to setup with my readnas102 a remote connection to server to backup, using the remote rsync but I get teh error above, and as I run a test with putty to connect to se...
Aug 22, 2026Guru - Experienced User
It might be easier to troubleshoot this if you use the linux command line instead of the NAS backup job. Once you get the basic folder copying working, it should be pretty easy to get the NAS backup job to work.
There a lot of things that could be wrong.
hussVLC
Aug 23, 2026Aspirant
i did test using putty, but I dont have the knowledge how to use linuex from windows oto program the tasks
