Karl-Heinz
Feb 16, 2016Star
esata Power
Hello I tried to attach a Harddisk by a eSataP cable but the Harddisk isn't waking up. seems that there isn't power. The slot on the NAS seems a power eSata but i'm not 100% sure. can you confi...
Feb 17, 2016Guru - Experienced User
The connector isn't eSATA-P. So you do need a power brick for the disk.
Karl-Heinz
Feb 17, 2016Star
This should be changed for sure. A box which cost 600 EUR I think the price difference from a eSata to eSataP when it will build in can't be such high. The current is already there so only add one single pin.
All the hussle with extra caddy and cable could be easy avoided.
Now I have to look for a caddy and bought a useless esataP cable. I couldn't imagine that this isn't powered.
Hope that this will end on the desk of a technican as todo.
anyway thanks for the response.
- StephenBFeb 17, 2016Guru - Experienced User
Personally I think powered eSATA is quite rare. For external drives, the industry has largely has shifted to USB 3.0 since the NAS was released.
However, it would make a lot of sense for you to post this suggestion in the "ideas for storage" section, to put it on Netgear's list. Other forum members can also then vote for this feature.
