swapdonkey101
Jan 12, 2014Follower
Expansion Problem
Good Day I have an ultra 4 and went to add two new drives to the two I already have. Log messages appeared and stated "Unsuccessful mounting ftp share homes-snap" and "Found free space to expand th...
de_niro
Jan 14, 2014Guide
you must disable active snapshot before expansion depite there is no such things on the Frontview.
You will need to install SSH addon to check and remove snapshot
example
#lvdisplay
--- Logical volume ---
LV Name /dev/c/c_2014_01_14_00_54 <====if you see the LVM snapshot,then delete it
VG Name c
#umount /c_2014_01_14_00_54
#lvremove /dev/c/c_2014_01_14_00_54
Do you really want to remove active logical volume "c_2014_01_14_00_54"? [y/n]: y
Logical volume "c_2014_01_14_00_54" successfully removed
example
#lvdisplay
VG Name c
