KillerBob
Oct 13, 2015Aspirant
Ext4 issues on FW 6.4.0
I have a ReadyNAS Ultra 2, which I use for backup. Connected to it I have a HDD caddy with 2 disks, both formatted to Ext4. I have shares on these and backup to them regularly. I did this today, and ...
jjanci
Oct 14, 2015Aspirant
I have same problem since I updated firmware to 6.4.0
Most of the time I using USB Toshiba 1TB (NTFS) works OK just before update.
After update, when I connect HDD message pops "External storage device connected" but is dificult to work wit it.
-backup task doesnt work
-I cant format hdd as before...
then I connect 64GB USB stick, that works fine as at firmvare 6.2.4
I'll tryed another one USB 4TB toshiba and same message as KillerBob apper "System: External storage device is connected but the file system is not recognized."
All drives still works fine with PC.
I tryed to downgrade firmware to 6.2.4 but that doesnt work too.
Its realy disapointing me, all external backups are outdated now. I just hope that nothing happend before fix firmware be released.
cpu8088
Oct 15, 2015Virtuoso
that message """External storage device connected""" popped up even with my 312
i went to share and highlight the usb-hdd xxx and checked allow anonymous.
after that done read and write on ntfs no prob
