semola1
Nov 15, 2015Tutor
External Disk not recognized
Hi all, I have disconnected a USB external disk for few days from my Netgear RN102. Now, when I have reconnected it, the Nas doesn't recognize the disk. The data are safe, if I connect the disk d...
- Nov 16, 2015
Your logs indicate
volume is dirty and "force" flag is not set
If you hook the external disk up to your PC and repair it you should then be able to connect it to the NAS again.
semola1
Nov 16, 2015Tutor
Hi BrianL,
before writing to community I have already tested the disk without any error.
I'm perplexed to upgrade my nas to a beta release, because on internal disk I have all my backups.
The beta release is stable? Can I update without problem?
Thanks
Semola1
mdgm-ntgr
Nov 16, 2015NETGEAR Employee Retired
Your logs indicate
- semola1Nov 17, 2015Tutor
I have repeated the disk test and I solved.
Thanks.
Marcello
