PropTop99
Jan 15, 2018Aspirant
External HDs no longer recognizing
External HDs on the ReadyNAS 312 seems to flake out and now no longer show up. - Rebooted the NAS, connected to a different USB port, connected to Server (showed up) did a reformat anyway, did a 'sc...
Marc_V
Jan 18, 2018NETGEAR Employee Retired
Hi PropTop99
Have you removed the disk on your server by ejecting it? Or just unplugging?
How many times have you tried doing a repair on the external HDD?
Kindly send me a download link on the logs so we can check.
Regards
- PropTop99Jan 18, 2018Aspirant
Hello Marc,
The customer has 2 WD External HDs that they swap out. The BU is configured to eject the drive after the BU has completed.
With respect to the server, I had them plug it in and I remotely did a scandisk, previously a format, and I ejected the disk and had her plug it back into the NAS using both the top, bottom and front ports with the NAS not picking up the drive at all.
The 2nd Internal Drive on the NAS was replaced a week ago but the issue was occurring before that as well. (reported potential impending failure)
I've attached the logs which shows the issue occurring and getting worse with the drive connecting and disconnecting repeatedly for some reason.
Thanks.
It appears that you CAN'T attach a log file because it's a ZIP?? Ok, please change the extension from .pdf to .zip and extract it.
- StephenBJan 18, 2018Guru - Experienced User
There is information leakage if you publicly post logs, which creates some privacy loss. Netgear recommends emailing them as described here: https://kb.netgear.com/21543/How-do-I-send-all-logs-to-ReadyNAS-Community-moderators#SUBMIT
They are also fine with storing them in a repository (dropbox, google drive, etc), and either emailing or PM (private messaging) the link.
Logs removed from the Post and sent to Support.
Thanks for the heads-Up StephenB!
R.
