lightsabre
Mar 19, 2013Guide
External USB Drive Corruption
There are a number of factors, so not sure where the cause lies. I figured I'd put it out there, as either a warning or for gathering intel! I had a Seagate GoFlex USB 2.0 2TB drive connected to a ...
lightsabre
Mar 20, 2013Guide
Thanks for the responses and ideas for consideration.
The drive, and NAS, is protected by a top-tier APC UPS, so it should not be a dirty power issue. It certainly is possible the hardware failures are purely coincidental, nonetheless I will approach managing the drive via Mac OS X and writing to the replacement USB drive with a bit of trepidation. "Twice burned..."
