fjester's avatar
fjester
Follower
Mar 24, 2018
External USB3 drive not detected after update to firmware 6.9.3 on readynas104
After updating to firmware 6.9.3 yesterday, the device is no longer detecting my external USB3 hard drive.
I've plugged the drive into my macbook and it doesn't appear to have any issues.
Drive is a WD My Book, 3TB, formatted with NTFS.
I'm not seeing it detected on either hotplug into the readynas104 or on reboot (via dmesg) as a usb or block device.
It's also not listed via fdisk -l.
Has anyone else experienced this problem? Can someone from netgear confirm the issue with this firmware version?
  • JohnCM_S's avatar
    JohnCM_S
    NETGEAR Employee Retired
    Hi fjester,
    Are you still having the same issue on your NAS? You may just provide to us the logs. The steps in providing the logs are indicated on this link.
    JohnCM_S
    NETGEAR Community Team
  • JohnCM_S's avatar
    JohnCM_S
    Hi fjester,
    Can you download the NAS system logs and then provide it to us? You may check this link on how to send the logs.
    JohnCM_S
ProSupport for Business
