willy134uk
Aug 01, 2012Aspirant
extracting rars with duo v2
hi is there a easy way of extracting rar files with the duo v2 ive read you can do via ssh but to complicated ive connected via ssh using telnet but dont know what to do from there thanks mark
codarz360
Dec 04, 2012Aspirant
Thank you very much for making me aware of that and it has now resolved my issue.
A note to anyone else that has this issue - ensure that you have the line:
Then just run a
Then type
in your /etc/apt/sources.list file.
deb http://ftp.uk.debian.org/debian sid main non-free
Then just run a
sudo apt-get update- this will now update the new packages.
Then type
sudo apt-get install unrarand BOOM problem solved!
