peter_jansen
Oct 04, 2011Aspirant
Factory Default NV+
Hi, How long does it take to factory default an NV+? I started the factory default process (after replacing 4 disks of 750GB with 4 disks of 2000GB), the LED displays: Factory Default, Please wait....
peter_jansen
Update on this issue. I have interupted factory reset.
Started checking drivers: Seagate ST32000641AS.
Connect to PC with SATA and run Seagate Seatools for Windows. 1 (one) drive is not found with this tool, other 3 drivers show OK on
tests (Smart Check, Short DST, Short Generic).
Is it possible the factory reset dit not work because one of the drives is not working?
Thanks
Peter Jansen
Thanks
Peter Jansen
