peter_jansen
Oct 04, 2011Aspirant
Factory Default NV+
Hi, How long does it take to factory default an NV+? I started the factory default process (after replacing 4 disks of 750GB with 4 disks of 2000GB), the LED displays: Factory Default, Please wait....
mdgm-ntgr
Oct 04, 2011NETGEAR Employee Retired
A dead drive not working would be the explanation for your factory reset not working.
It'd be best if you could run long SeaTools tests on your good 3 drives that show O.K., but it should work fine if you factory reset with just those drives in place.
