bolter
May 29, 2022Aspirant
Factory reset readynas ultra 6 running OS 6
IF I Factory Reset My Readynas Ultra 6 running OS6 Because I Don't Seem To Have Any Apps Any more (Plus A Couple Of Other Small Niggley Issues) Will It Reset The OS Back To V4.xxx That It Came With. ...
- Jun 05, 2022
I Did A Factory Reset On The Nas, This Still Didn't Give Me Any Apps.
But Re-Install OS 6.10.7 and This Has Given Me Apps Back Again.
May 29, 2022Guru - Experienced User
It will reinstall OS 6. It is possible to downgrade if you really want to do that (but you can't run Plex on 4.2 firmware).
bolter wrote:
The Main Reason To Reset Is I Can't Install Plex.
I've seen a couple of reports on plex misbehaving with 6.10.7 firmware. Not sure what the issue is (personally I run plex on a windows PC, with the NAS data volume mapped to a drive letter). Marc_V , JeraldM - do you know if anyone at Netgear is working with Plex to resolve this?
But I believe plex can be installed if you downgrade the firmware to 6.10.4.
