yeneric
Sep 01, 2012Aspirant
Failed Drive - Can't Boot! HELP! #19341286
Hi everyone, I hope someone out there can give me some guidance as I no longer have access to my data and somewhat stressed to say the least... I've got the ReadyNAS NV and it's been working fla...
mdgm-ntgr
Sep 09, 2012NETGEAR Employee Retired
It's possible disk 2 might be fine. When you last did a factory default or initial setup were there two or fewer disks installed? It's possible disk 2 is the parity disk. If this is the case it's normal for there to be no partition table on the disk and for the disk to appear to be uninitialised to your PC. Data recovery using a parity disk would only be possible in a ReadyNAS.
To attempt to clone a damaged disk use dd_rescue not dd.
Rabbie wrote:
It is better do clone job as below instruction:
CLONE DISK:
Use a Knoppix 6.2 Live CD for this guide. Can be found at http://www.knoppix.net
Using dd_rescue command allows you to copy data from one drive to another block for block. This is especially useful for recovering a failed drive. Often when a drive fails, the drive is still accessible, it has just surpassed the S.M.A.R.T. error threshold. dd_rescue allows you to ignore the bad sectors and continue cloning the bad drive to a new healthy drive.
1) Connect your old drive and new drive to your PC
2) Boot up using your Linux live CD
3) Launch a terminal window.
4) Run fdisk -l to make sure the system sees both of the hard drives.
5) Run hdparm -i /dev/sdx on both of the drives to find which drive is your source drive and which drive is your destination drive
6) Once you know which drive is which you can start the clone process.
dd_rescue /dev/sdx(source disk) /dev/sdx(destination drive)
7) You will see the process start, just keep an eye on it, it might take a few hours for the clone job to finish, depending on the size of the drive.
Once the process is complete, there will be no notification, the transfer will just stop and you will see the terminal prompt again.
If you see a lot of errors or see that there is no more data being shown as succxfer: it means the drive got marked faulty by the kernel. At this point reboot the system and make sure you know which drive is which again, as it is possible they lettering might switch. Run the dd-rescue command again but this time with -r option. This will start the cloning again but this time will start from the back of the drive and will make sure to get the data that has not been cloned yet.
