yeneric
Sep 01, 2012Aspirant
Failed Drive - Can't Boot! HELP! #19341286
Hi everyone, I hope someone out there can give me some guidance as I no longer have access to my data and somewhat stressed to say the least... I've got the ReadyNAS NV and it's been working fla...
mdgm-ntgr
Sep 14, 2012NETGEAR Employee Retired
There's a 2GB OS partition and the data volume is on a separate partition. If the partition table and the 4GB OS partition is fine that "might" be able to be mounted and the logs would be in there. If your data is important I would suggest contacting a data recovery company.
