AKLGUY
Aug 20, 2021Apprentice
Failed Hard Drive Upgrade
Hi Team. I have an RN316 slowly built it up to have 6x 3TB Drives. (started with 3) Then I have slowly replaced the 3TB drives with 8TB Drives (one at a time) For a while I was running fine on ...
- Aug 28, 2021
AKLGUY wrote:
Failed to expand volume with disk Model: WDC WD30EFRX-68EUZN0 from Channel 5. Volume requires drive capacity to be the same size or larger before volume expansion can begin.
Does the System to really want me to replace the last 2 3TB bays with 8TB I wonder?
Note it was telling you it can't expand the volume (which is true). Though it is a confusing message to get on a disk replacement.
AKLGUY
Aug 24, 2021Apprentice
I have finished the Resync, and started to put my content back but when I now look at the NAS Bay 4 is Red (steady) It is still showing as ok here. I am doing a disc check now but the numbers are correct arent they for what I should have (raid 5 X-Raid) The only difference is the 8TB in by for is a WD Red Plus (7200 RPM) while the others are 8TB Red at 5400
Aug 25, 2021Guru - Experienced User
The volume size is correct.
- AKLGUYAug 25, 2021ApprenticeThanks but there is a red light on the NAS drive bay(sorry I wasn’t clear above)
- AKLGUYAug 25, 2021ApprenticeThe Disc check on the NAS said Drive 4 failed. Do I guess I order a new drive and get this replaced
- StephenBAug 26, 2021Guru - Experienced User
AKLGUY wrote:
The Disc check on the NAS said Drive 4 failed. Do I guess I order a new drive and get this replacedThis is the drive you just purchased, correct? If so, you should be able to exchange it with the seller. The vendor warranty generally gives you a recertified drive with a one-year warranty, the seller should give you a new one.
If it's not new, then start by checking the warranty status at the vendor's website. That will require the serial number.
