AKLGUY
Aug 20, 2021Apprentice
Failed Hard Drive Upgrade
Hi Team. I have an RN316 slowly built it up to have 6x 3TB Drives. (started with 3) Then I have slowly replaced the 3TB drives with 8TB Drives (one at a time) For a while I was running fine on ...
- Aug 28, 2021
AKLGUY wrote:
Failed to expand volume with disk Model: WDC WD30EFRX-68EUZN0 from Channel 5. Volume requires drive capacity to be the same size or larger before volume expansion can begin.
Does the System to really want me to replace the last 2 3TB bays with 8TB I wonder?
Note it was telling you it can't expand the volume (which is true). Though it is a confusing message to get on a disk replacement.
AKLGUY
Aug 25, 2021Apprentice
Thanks but there is a red light on the NAS drive bay(sorry I wasn’t clear above)
AKLGUY
The Disc check on the NAS said Drive 4 failed. Do I guess I order a new drive and get this replaced
- StephenBAug 26, 2021Guru - Experienced User
AKLGUY wrote:
The Disc check on the NAS said Drive 4 failed. Do I guess I order a new drive and get this replacedThis is the drive you just purchased, correct? If so, you should be able to exchange it with the seller. The vendor warranty generally gives you a recertified drive with a one-year warranty, the seller should give you a new one.
If it's not new, then start by checking the warranty status at the vendor's website. That will require the serial number.
- AKLGUYAug 26, 2021ApprenticeSadly none in the country at the moment.
The red light on the nas shows bay4 but the disc check actually said bay5 is faulty could the red light still mean it is trying to resync even though the OS and the web GUI says it’s finished?- StephenBAug 26, 2021Guru - Experienced User
AKLGUY wrote:
but the disc check actually said bay5 is faulty could the red light still mean it is trying to resync even though the OS and the web GUI says it’s finished?What are you seeing on the graphic on the volume page?
I'd be more inclined to trust the OS log, but probably you should test both in a Windows PC.
