AKLGUY
Aug 20, 2021Apprentice
Failed Hard Drive Upgrade
Hi Team. I have an RN316 slowly built it up to have 6x 3TB Drives. (started with 3) Then I have slowly replaced the 3TB drives with 8TB Drives (one at a time) For a while I was running fine on ...
- Aug 28, 2021
AKLGUY wrote:
Failed to expand volume with disk Model: WDC WD30EFRX-68EUZN0 from Channel 5. Volume requires drive capacity to be the same size or larger before volume expansion can begin.
Does the System to really want me to replace the last 2 3TB bays with 8TB I wonder?
Note it was telling you it can't expand the volume (which is true). Though it is a confusing message to get on a disk replacement.
AKLGUY
Aug 27, 2021Apprentice
Just finished testing the old bay 4 drive and it passed so Zeroed the data.
Placed it in Bay 5 (which Readynas said had failed) Both old 4 and the bay 5 drives were 3TB Red Drives.
(Previous) Bay 5- WDC_WD30EFRX-68EUZN0
Old Bay 4 now in Bay 5 WDC WD30EFRX-68EUZN0
This is the error message I got right before it said it was starting the resync
Aug 28, 2021Guru - Experienced User
