X_ray
Nov 15, 2012Aspirant
Failed upgrade
I have a ReadyNAS NV+ that I tried to upgrade the firmware this Monday. After the usual upgrade message, I got the "please reboot" message and I did. It did not reboot quickly. On Wednesday (2 days...
atanas2
Tried OS reset. Does not work.
Did you try OS - re-install from the boot menu? Can you boot the system in tech support mode?
Also you can call NETGEAR support and open a case.
