it-partner
Feb 14, 2017Aspirant
Failure with smb or iscsi connection ReadyNAS 214
Firmware 6.6.1 When we are uploading files to NAS via SMB or to vdisk via iscsi connection after few minutes uploading connection faild. No any messages in logs, it will work again after reboot. ...
mdgm-ntgr
Feb 14, 2017NETGEAR Employee Retired
The logs show that AV is already disabled.
Perhaps try disabling IPv6.
Also your NAS is showing a 100Mbit connection. Are you using a 100Mbit router/switch? Can you try using a gigabit router/switch and see if you still have the same problem?
