it-partner
Feb 14, 2017Aspirant
Failure with smb or iscsi connection ReadyNAS 214
Firmware 6.6.1 When we are uploading files to NAS via SMB or to vdisk via iscsi connection after few minutes uploading connection faild. No any messages in logs, it will work again after reboot. ...
Retired_Member
Feb 25, 2017If not already done, try to install the app "SMB plus" and set the parameters as follows
SMB Version -> SMB3
Oplocks -> disable
Preallocate -> enable
Hide unreadable -> disable
Hide unwriteable -> disable
Restrict anonymous -> disable
SMD encrypt -> auto
SMB signing -> disabled
Good luck :-)
The app is running fine on my two NAS (RN104 and RN204) since beginning of (2014; 2016) and seems also not to misbehave under fw 6.6.1
- aalexandrebetaFeb 25, 2017Master
Interresting topic!
- it-partnerFeb 26, 2017Aspirant
Thanks i will try it.
At this moment we cut max size of the lunes after this it has been working for last week without problems.
