Naslok
Aug 16, 2017Aspirant
Fan in fullspeed ( readyNAS 102)
Situation:
- ReadyNAS RN102 F.W. : 6.8.0
- RAIDar: 6.3.0
Problem:
The fan in my Nas is continious in full speed, While the dashboard says it's not working.
The temperature of the HDD's is 32 degrees celcius, the processor 42 degrees.
Looking for a solution............:-(
It sounds like the fan sensor might have failed.
Is the NAS still covered by warranty (1 year from date of purchase)?
- Marty_MNETGEAR Employee Retired
Hello Naslok,
Unfortunately the warranty status of the NAS is already expired. If you have a back up of the data save on the NAS you have an option to perform an OS re-install or factory reset the NAS and check if it will make any difference.
Welcome to the community!
Marty_M
NETGEAR Community Team - NaslokAspirant
No, Warranty is expired. :-(
Hello Naslok,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
