Homith
May 20, 2016Guide
Fan Problem After Upgrading To 6.5.0
Good Evening Community Members, Today I upgraded my RN314 to the 6.5.0 firmware. I really like some of the new features that have been added however I am now getting a strange problem with my fan on...
- May 25, 2016
Each time the fan jumps to a new RPM level (there are 7 possible levels based on various temperature readings), it must calibrate the fan for that RPM level once each boot. During that calibration period, which should take between a few seconds and 3 minutes, you may hear the fan speed up or slow down more than normal. But once that is done, it should be stable.
We've also made some additional changes for 6.5.1 to take advantage of some hardware capabilities which should allow use to make fan adjustments more smoothly.
Homith
May 20, 2016Guide
Good Morning Skywalker,
Just wanted to let you know that at 1203pm (AEST (Melbourne/Australia) the ReadyNas 314 fans wen nuts again. The Fans sped up for about 1 min and after around 20 seconds came back down. Within the Status tab it was showing fan failure again. Now it has settled back down and fans are back to 797RPM and the Status indicates Green (Healthy). Fan profile is 'Quiet'.
Cheers
Skywalker
May 25, 2016NETGEAR Expert
