Han_Solo
Jul 06, 2005Tutor
FAQ - Measuring performance with IOMeter
Below are step I do to setup IOMeter. After you get an understanding of all the settings you can adjust them to test a specific test case you are interested in. If anyone has any questions just let ...
StuHolmes
Nov 21, 2011Aspirant
I have been having issues with my Duo for a couple of weeks now, really painfully slow to access.
IOMeter was showing read and write speeds of sub 1MB/s. :cry:
Stopping all services boosted it to 6-7MB/s ( I think it was Squeezeserver that made the difference), but this is still far too slow isn't it?
No network errors;
Network Errors [Ethernet 1]
Auto-negotiation 0
Bad packets 0
Disconnect 0
False carrier 0
Idle errors 0
Link failures 0
Receive errors 0
Symbol errors 0
VLAN tags 0
TCP Retransmits 9
Unrecovered TCP Retransmits 0
No errors on SMART info.
I've tried different cables, all cat6. Two routers. Downgraded to raidiator 4.1.7 in case it was an issue with the recent upgrade.
Don't know what else to try. Any suggestions???
No network errors;
Auto-negotiation 0
Bad packets 0
Disconnect 0
False carrier 0
Idle errors 0
Link failures 0
Receive errors 0
Symbol errors 0
VLAN tags 0
TCP Retransmits 9
