Han_Solo
Jul 06, 2005Tutor
FAQ - Measuring performance with IOMeter
Below are step I do to setup IOMeter. After you get an understanding of all the settings you can adjust them to test a specific test case you are interested in. If anyone has any questions just let ...
JasonR1
Mar 04, 2012Aspirant
I had problem in step 4 "When IOMeter is up and running go to the “Topology” field and select your PC name and when the tree expands select “Worker 1”. ". .. this thread solved it.. Thanks
