Han_Solo
Jul 06, 2005Tutor
FAQ - Measuring performance with IOMeter
Below are step I do to setup IOMeter. After you get an understanding of all the settings you can adjust them to test a specific test case you are interested in. If anyone has any questions just let ...
wardmw
Apr 22, 2012Aspirant
Hi all,
I am having a problem getting IOMeter to see my network share. It exists OK, I mapped it by using:
c:\> net use m: \\192.168.2.10\media
and entering a user ID and password since it's secured. I can view the contents of the share successfully in Windows and in a DOS box:
c:\> dir m:\
However I cannot get IOMeter to see the network drive. It shows the local and USB drives but not the network ones.
Any suggestions? Its a RND4000 ReadyNAS NV+ with two disk in RAID-X if that helps.
|\/|artin
c:\> dir m:\
|\/|artin
