williamyzfr1
Apr 06, 2014Guide
FAT 32
I am using Windows 7 and was trying to access and write to a USB HDD connected to my Readynas 102. Initially I couldn't access the drive but solved that issue with "Allow Anonymous Access" but I still...
Apr 06, 2014Guru - Experienced User
What firmware are you running? NTFS should have worked fine. I see one post from someone who had a similar issue, but haven't seen anyone else. If you can duplicate this problem, you should contact netgear support.
FAT32 can't handle files > 4 GB, so it is not a good choice unless you are certain all your files are smaller.
