nasischijf
Sep 22, 2013Aspirant
FDISK errors on RN102/OS6
Is the WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! bad? I have a WD Red 3TB in the NAS and just connected a 1TB drive via usb3.0, I want to use this one for backup. Erro...
Sep 22, 2013Guru - Experienced User
NOTE- I split this from the original topic, since it was totally unrelated
I see the same sort of errors, but everything appears normal.
None of these are file system errors, fdisk isn't recognizing the partitions below the file system.
