nasischijf
Sep 22, 2013Aspirant
FDISK errors on RN102/OS6
Is the WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! bad? I have a WD Red 3TB in the NAS and just connected a 1TB drive via usb3.0, I want to use this one for backup. Erro...
nasischijf
mdgm wrote: With disks that use the GPT partitioning scheme you need to use sgdisk not fdisk to print the partition table. fdisk only supports the MBR partitioning scheme. For disks larger than 2TB in capacity the GPT partitioning scheme is needed. For your internal and external disks run these commands:
# sgdisk -p /dev/sda
# sgdisk -p /dev/sdb
Aaah okay, so there's nothing to worry about, the only point is that fdisk is not equipped to correctly show the information. Thanks!
