timnas
Jan 20, 2017Aspirant
File system broken after power cut down
Recently, there were electrical works in my building and appartment that caused a power cut down. The beep of my UPS was probably to annoying for workers so they decided to unplug the NAS that was t...
FramerV
Jan 21, 2017NETGEAR Employee Retired
Hi timnas,
I apologize but I think this is for phone support already. Seems to be complicated already given the things that occurred. Check if you still have support warranty via my.netgear.com; if none, you can get a per-incident support.
- timnasJan 31, 2017Aspirant
FramerV wrote:I apologize but I think this is for phone support already. Seems to be complicated already given the things that occurred. Check if you still have support warranty via my.netgear.com; if none, you can get a per-incident support.
Thank you for you suggestion.Since it is available only 90 days, support period had ended years ago for me (2012).
I'm not ready to pay for a phone support session, so I'd better go with the factory reset option.
I will know if it is a hardware or a software failure then.
