timnas
Jan 20, 2017Aspirant
File system broken after power cut down
Recently, there were electrical works in my building and appartment that caused a power cut down. The beep of my UPS was probably to annoying for workers so they decided to unplug the NAS that was t...
JennC
Jan 25, 2017NETGEAR Employee Retired
Hello timnas,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- timnasJan 31, 2017Aspirant
To be honest, I was expecting more something like
StephenB says: No worries buddy, your data are still there.
Just apt-get foo-barfs and mount a ext4 volume with offest 42.Me : Dude, you're the guru among the gurus.It works like a charm.
Please accept my eternal gratitude. May I pay you with Beercoins?
Anyway, and at last, I was able to retrieve all my data from my 2 TB HDD just today.I am now able to mount every partition:
- System (ext3 - 4GB)
- Restore? (can't remember - 512 MB)
- Data (ext4 - 1.8 TB)
But if I am now technically able to fix the booting issue of the NAS, I don't know what to start with.
I guess a serial console would help debugging the booting process, or a directly-connected display...
In last resort, I will buy a new HDD and proceed to a factory reset :(
- StephenBJan 31, 2017Guru - Experienced User
Please accept my eternal gratitude. May I pay you with Beercoins?Beercoins? You didn't say that before :smileywink:
Your situation looked delicate, I didn't want to offer advice that might backfire and make it worse. FramerV's suggestion on paid support seemed appropriate to me.
