timnas
Jan 20, 2017Aspirant
File system broken after power cut down
Recently, there were electrical works in my building and appartment that caused a power cut down. The beep of my UPS was probably to annoying for workers so they decided to unplug the NAS that was t...
FramerV
Jan 21, 2017NETGEAR Employee Retired
Hi timnas,
I apologize but I think this is for phone support already. Seems to be complicated already given the things that occurred. Check if you still have support warranty via my.netgear.com; if none, you can get a per-incident support.
timnas
Jan 31, 2017Aspirant
Thank you for you suggestion.
Since it is available only 90 days, support period had ended years ago for me (2012).
I'm not ready to pay for a phone support session, so I'd better go with the factory reset option.
I will know if it is a hardware or a software failure then.
- StephenBJan 31, 2017Guru - Experienced User
True enough.
What model is this?
- timnasFeb 01, 2017Aspirant
Wow, I'm sorry this info is not shown, I'm pretty sure I had to select my Readynas model in the form to start this thread.
It is a Readynas Duo v2.
PS : yes I did:
SpoilerModel (Recommended - Helps the community give the best answers)
- StephenBFeb 01, 2017Guru - Experienced User
Which is difficult, because there are so many models. Anyway I was wondering if it was still covered by the hardware warranty, but unfortunately it isn't.
But I think you'll find that the hardware (including disks) are fine - usually what happens is that the power cut results in some file system corruption (often of the OS partition), which results in an unbootable system. Based on posts here, I think the OS 6 NAS are less vulnerable to that particular problem.
