timnas
Jan 20, 2017Aspirant
File system broken after power cut down
Recently, there were electrical works in my building and appartment that caused a power cut down. The beep of my UPS was probably to annoying for workers so they decided to unplug the NAS that was t...
timnas
Jan 31, 2017Aspirant
FramerV wrote:
I apologize but I think this is for phone support already. Seems to be complicated already given the things that occurred. Check if you still have support warranty via my.netgear.com; if none, you can get a per-incident support.
Thank you for you suggestion.
Since it is available only 90 days, support period had ended years ago for me (2012).
I'm not ready to pay for a phone support session, so I'd better go with the factory reset option.
I will know if it is a hardware or a software failure then.
