Chainsawdave-1
May 08, 2016Aspirant
File/Folder Permission Issue - Intermitant
Hi I have ReadyNAs Pro 6 running RAIDiator 4.2.28. It's access by a Mac, Unbutu, PCs running XP, Windows 7 and Now Windows 10 respectively. I'm having intermitant file and folder access issues. ...
May 12, 2016Guru - Experienced User
Do you have multiple user accounts on the NAS? It is likely that some of the files or folders have different owners, which does affect what other users can do.
Have you tried resetting the owner/group from the "advanced" tab for the share?
Also, is this happening in one of the built-in shares, or one that you created yourself?
Chainsawdave-1
May 18, 2016Aspirant
Hi StephanB
Thanks for your response. All of the folders are ones I created. I did try changing the permissions by they just reset. I have also tried turn it off turn it on again. This sometimes helps.
It's hard for me to test any other ideas as the damm things is working perfectly at the moment. I hate intermittant faults.
D..
