Chainsawdave-1
May 08, 2016Aspirant
File/Folder Permission Issue - Intermitant
Hi I have ReadyNAs Pro 6 running RAIDiator 4.2.28. It's access by a Mac, Unbutu, PCs running XP, Windows 7 and Now Windows 10 respectively. I'm having intermitant file and folder access issues. ...
BrianL2
May 11, 2016NETGEAR Employee Retired
Hi Chainsawdave-1,
Welcome to the community!
Try to executing this command 'net use * /delete' (without the prime symbol) in Command prompt in those PCs where you're experiencing permission problems.
Look at this thread for more information.
Kind regards,
BrianL
NETGEAR Community Team
Chainsawdave-1
May 18, 2016Aspirant
Hi Brian
Thank you for your response. I will try this! At the moment it's working fine. I didn't do anthing that i am aware of to fix it. But I have book marked your suggestion and if it happens again will try this and repost.
Thanks
D..
- BrianL2May 18, 2016NETGEAR Employee Retired
Hi Chainsawdave-1,
No worries. Since your issue is now resolved, we encourage you to mark this thread closed by clicking the "Accept as Solution" button in one of the responses that you received.
Kind regards,BrianL
