stanbridge30
Mar 15, 2018Aspirant
Files not showing on MAC
Please Help! I have no idea what i'm doing. I have had this server for about 7 years - it has all my films on it (i'm a film maker) Recently I upgraded my mac to Sienna and although the fileserver ...
Mar 16, 2018Guru - Experienced User
What firmware is your NAS running?
Can you access the NAS web ui by entering https://nas-ip-address/admin in your browser address bar?
- stanbridge30Mar 18, 2018Aspirant
how do i find out what firmware is running? also now says c: unprotected? Thanks again
- StephenBMar 19, 2018Guru - Experienced User
The NAS admin UI ( https://nas-ip-address/admin )will tell you that, as will RAIDar ( https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar ).
If you entered the correct model number (ReadyNAS 1100 - which is a 4-bay rack mount), then the firmware should be 4.1.x. If the model was entered incorrectly, then it might also be 4.2.x, 5.3.x, or 6.x.x. A picture of the 1100 is below.
That means a disk has failed (or been removed).
- stanbridge30Mar 19, 2018Aspirant
Hi stephen,
Thanks for getting back to me.
The model on the front says Ready Nas NV + v2. I've attached an image if that helps?
